Re: Re: Gas Pistons (Super M vs 400)
Posted by wayne on September 21, 2001 at 06:29:47 from (216.188.199.193):
In Reply to: Re: Gas Pistons (Super M vs 400) posted by Dale13 on September 21, 2001 at 05:16:30:
As far as dome height is concerned, the high altitude firecraters for the M have a 3/4" dome height. Both the M&W and firecraters have about the same HP increase. As far as the part number of the pistons, the 4" Super M piston was also used in the 4" increased bore piston and sleeve set. The pistons are interchangeable, but the sleeves are not.
Post A Followup
: Re: Re: Re: Gas Pistons (Super M vs 400)
