Auxillary Hydraulic Valve on M with live hyd
Posted by Dick Davis on September 22, 2001 at 16:28:48 from (152.163.204.52):
Did a little fall disking and found hydraulic fluid pouring out of the auxillary hydraulic valve! It is coming from both sides of the opening where the cross shaft passes through the top of the valve body. Does anyone know, are there o rings on this shaft or is it a weld up and grind down to fit seal? An exploded view of the aux valve would be very appreciated, Dick
Post A Followup
: Re: Auxillary Hydraulic Valve on M with live hyd
