Re: Cub spline and clutch shaft replace
Posted by the tractor vet on September 23, 2001 at 21:00:14 from (216.196.12.118):
In Reply to: Cub spline and clutch shaft replace posted by Fred Sachtleben on September 23, 2001 at 16:30:57:
You will have to split the tractor at the transmission and pull the shifter off and remove the ft. bearing. and if you are careful you can slide the shaft out and not pull the top gears out but if you have never done this before the remove your shifter forks and as you pull the shaft out remove the gears , also pull the PTO out and replace the shift fork on the PTO and check everything you may end up like my brother and up replacing all the bearings in the transmission and diff. you can get and aftermarket shaft for under a 100 bucks . I think that we had about 350 in parts in his cubby and if i would have charged him it would have been about 275 to 300 for all labor.
Post A Followup
: Re: Re: Cub spline and clutch shaft replace
