Re: cub float adjustment
Posted by Dave T on September 24, 2001 at 10:53:50 from (63.27.107.128):
In Reply to: cub float adjustment posted by Kajun on September 24, 2001 at 07:41:43:
Turn carb upside down, without gasket. Measure from the carb base (where the gasket was) to the top of float. Your tractor mechanics just adjusts them so the float is parallel with the carb....check the shape of your needle valve. Some of these are rubber, but the rubber gets very hard over the years, and no longer seals as well, which causes problems too.
Post A Followup
: Re: Re: cub float adjustment
