F-20 axle leaking oil
Posted by eric on September 24, 2001 at 10:55:36 from (165.121.81.203):
I have a oil leak at the rear axle shaft out by the wheel. The manual I have shows that you have to completely disassemble the bull gear housing to get the axle stub shaft out.Can I just remove the small cover on the inside of the bull gear housing and drive the axle out of will the bull drop down? I would like to fix this problem without major disassembly as the tractor has a fairly new paint job. All help appreciated.
Post A Followup
: Re: F-20 axle leaking oil
Today's Featured Article - Talk of the Town: How to Remove a Broken Bolt - by Staff. Another neat discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "I have an aluminum steering gear housing with a bolt broken off in it. The bolt is about a 3/8" x 1 1/2" bolt. I've already drilled the center of the bolt out with about 7/64" drill bit the entire length of the bolt. Only one end of the bolt is visible. I tried to use an easy out but it wasn't budging and I didn't want t ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
