Re: F-20 axle leaking oil
Posted by Al P. on September 24, 2001 at 14:59:38 from (208.253.190.223):
In Reply to: F-20 axle leaking oil posted by eric on September 24, 2001 at 10:55:36:
Eric,
I have just rebuilt both final drives on my tractor and relaced all felt seals. If i understand you correctly you are looking to replace the felt seals on the end of the Stub Shafts. these shafts can easily removed. after you remove tire Assembly remove the caps on the inside of the final drive housing. inside you will find two nuts with washer between, straighten the washer and remove the nuts and washers. axle can now be removed by taping with rubber mallet. Bull gear will stay in place as it is mounted on seperate bearing.
Al P
Post A Followup
: Re: Re: F-20 axle leaking oil
Today's Featured Article - Talk of the Town: Winterizing Engines - To Drain or Not to Drain? - by Russ Berry. What is this strange attraction I have to equipment and machinery? How did I get this way? I came from the suburbs and own a small horse farm in rural Loudoun County, Virginia. You can call me a "weekend farmer." The local farmers do. Does it bother me? No. I am just happy to have their friendship. At least the word "farmer" is in my title. But what is the attraction? How can I explain the sensation and exhilaration I feel when I turn the key and hear the engine come to life (most ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
