Re: Re: Re: Re: OFF SUBJECT PICKUP PLOW
Posted by Moses55312 on September 25, 2001 at 07:56:03 from (207.16.136.3):
In Reply to: Re: Re: Re: OFF SUBJECT PICKUP PLOW posted by Brian on September 24, 2001 at 18:23:02:
Yeah, I would lift the plow up and down manually and see if it has full range of motion, and all the mehcanics are working o.k. If it does, you are probably not building enough pressure to pick it up. Could be a bad cylinder seal, allowing oil to bypass. I'm not sure what else is in the system, but I suppose it could be a pump problem, or if there is a relief valve, it may be stuck open or set too low.
Post A Followup
: Re: Re: Re: Re: Re: OFF SUBJECT PICKUP PLOW
Today's Featured Article - The Great Escape - by Dave Hollrah. It all began Monday with a little baling of second crop on the lake shore field, and as I drove out past my sister and her hubby's place, this small calling sound could be heard from the general direction of their manure pile. Out of the yard, over the cows and bale piles, through the dozer piles, poplars, and brush, out onto the ditch grade road, past the noisy 6.2 diesel engine pulling my well traveled Suburban along. Well it sure didn't take me long to figure out what it was because I alrea ... [Read Article]
