tractor not charging
Posted by abane on September 25, 2001 at 18:42:01 from (216.202.103.231):
I bought a tractor that had a lot of problems and have most worked out but I have one that is driving me up the wall. I have a 350 diesel Farmall and will not hold a charge. I had the same problem when I bought it and the voltage regulator was feeding back and not going to the generator.I PUT A NEW VOLTAGE REGULATOR ON AND it worked fine for a while but then it would run the battery down in an hour and the amp gauge WOULD show nothing, and you can the cables off the battery and it continues to run---any suggestions--
Post A Followup
: Re: tractor not charging
