Re: Questions about paint hardners and clearcoats
Posted by Daniel on September 27, 2001 at 10:12:43 from (206.74.50.21):
In Reply to: Questions about paint hardners and clearcoats posted by Chris Petersen on September 26, 2001 at 11:42:55:
I would consider getting a paint/hardner/reducer/clearcoat system from one source like PPG. I used Del-Star on my Super A and they had the codes to mix IH 2150. This way you're assured of getting compatable products and information on the mix ratios. Also, the IH paint may fade more than a auto paint. If your going to work the tractor, you might want to just use the IH paint without anything in it because it will be eaiser to touch up scratchs and wear and tear. Also consider a light grey primer instead of ruddy red because when your spraying the red it will be eaiser to tell if you've missed any spots. Good luck!
Post A Followup
: Re: Re: Questions about paint hardners and clearcoats
