Questions on M hydraulics
Posted by Lowell Davis on September 27, 2001 at 13:32:45 from (208.178.45.130):
Hello -
My '46 M has live remote hydraulics courtesy of an M&W pump behind the distributor and a Gresen (Minneapolis) two-position valve (stamped 2701) piped into the original belly reservoir. I've not yet been able to test them, but I'm considering getting a tandem disk and am wondering how things hook up. There are two hoses running to quick-disconnect fittings at the rear of the tractor. Is one a pressure line and one a return? What kind of cylinder should I be looking for to raise the disk? When I pull back on the valve control, the engine lugs; when I push forward, there's no change in engine speed.
Thanks in advance -
Post A Followup
: Re: Questions on M hydraulics
