Curious Numbers
Posted by EZHangin on September 30, 2001 at 06:31:21 from (216.211.7.85):
I have the following codes on cast items on my
1944 (FAA-107576)Farmall A.
6342-DH.........Engine
8846-DA.........Tranny
6716-DB.........Head
6502-DA.........Belt Pulley
8778-DA.........Timing Cover
8638-DB.........Clutch Bell
6530-DD.........Front End
What is the purpose behind these numbers ?
Are they part numbers ?
Can one tell by the numbers if a tractor is all original, or if it was rebuilt using a couple different tractor parts from different years ?
Just Curious, if anyone knows.
Post A Followup
: Re: Curious Numbers
