Re: Curious Numbers
Posted by Richard C on October 01, 2001 at 07:04:06 from (208.31.95.28):
In Reply to: Curious Numbers posted by EZHangin on September 30, 2001 at 06:31:21:
If you look on the top right hand corner of the right side of the engine block, there under all the grease and oil ( if your A is as dirty as my B) There should be a serial #. It should match your tractor serial number if it is the original block. That is also one way to date your tractor if missing the # plate.
Richard
Post A Followup
: Re: Re: Curious Numbers
