Re: how to revove the radiator from an H
Posted by Farmer Bob on September 30, 2001 at 20:33:25 from (66.152.73.151):
In Reply to: how to revove the radiator from an H posted by Andy on September 30, 2001 at 19:56:54:
Andy, First loosen the connection where the forward steering shaft fits into the knuckle up by the gauge gracket. Loosen the forward collar on the rear steering shaft up in front of the throttle and work it down the shaft a ways. You need to get the rear shaft to move back toward the seat and away from the forward shaft. Remove the woodruff key in the forward shaft as it will be in the way when you start turning the forward shaft through the bushing by the gauge bracket. Then remove the large plug on the front of the upper bolster and turn the forward shaft and worm gear out the gear box at the top of the upper bolster. Once the worm is free the shaft just slides out through the radiator and gear box. May as well check the bearing that sits in front of that worm gear. Sometimes they are bad and it would give you a chance to replace it while doing all this work.
You should also have the two stud bolts on the bottom of the radiator with most likely castellated nuts and maybe even cotter pins. Remove the pins and nuts and the radiator should lift off the tractor.
Be thankful you have a later model H, you shouldn't have any problems getting a socket on those bottom stud nuts. Just use a long extension on your socket wrench.//FB
Post A Followup
: Re: Re: how to revove the radiator from an H
Today's Featured Article - Product Review: Kreem Brand Fuel Tank Liner - by Staff. This condition has occurred on a few machines that we have had and fortunately we were able to borrow the technique used at the local motorcycle shop. The product that we have used is called Kreem thouh there are others on the market, this one was recommended and available. This particular product is sold in three parts, a bottle of etch, dryer, and sealer. We were fortunate enough to start the process with stern warnings from those that had used this type of product before. The horror ... [Read Article]
