Re: Re: how to revove the radiator from an H
Posted by Theman on October 01, 2001 at 07:27:49 from (12.19.86.5):
In Reply to: Re: how to revove the radiator from an H posted by Farmer Bob on September 30, 2001 at 20:33:25:
A couple of things to add to the previous post: There is a seal in the bolster where the shaft enters it. Make sure you scrape the crud buildup off of the shaft before you remove it or you could damage the seal and get dirt in the gear box.
The other thing you will need to do before lifting the radiator up is to remove the fan shroud. There are long bolts that go through the radiator sides holding the shroud. The shroud can then be moved back (it doesn't have to be completely removed) around the fan so the radiator can come straight up.
Post A Followup
: Re: Re: Re: how to revove the radiator from an H
