Re: H transmission fun!
Posted by Denny Frisk on October 01, 2001 at 12:38:30 from (12.4.181.2):
In Reply to: H transmission fun! posted by marvin on October 01, 2001 at 11:49:40:
If You look closely under the little stamped steel cup shaped piece at the bottom of the gear shift lever You'll see 2 small, about 1/2" dia. steel plugs. Chances are one may have a hole in it that You could stick a punch in and drive out the steel pin the gearshift lever pivots on. Once it's out of the way a big screwdriver is all that's needed to line up the slots for the bottom of the gearshift lever in the tops of the shifting forks. Dad's old '39 H was doing that 30+ yrs ago.
Post A Followup
: Re: Re: H transmission fun!
