Re: Re: 12 V Conversion - Helpful Hint
Posted by Grove r on October 03, 2001 at 16:27:49 from (161.184.22.55):
In Reply to: Re: 12 V Conversion - Helpful Hint posted by Moose on October 03, 2001 at 15:04:27:
Hi, Moose, know what you mean about old age... Thanks for the tip, I have problems with two alternators I installed, one, a WFourklift, [spellings OK, I built it, so I can call it what I want! ";^) }, the other is on a 180 Lincoln welder. Realy suspect the pulleys are too big to start the initial charge, unless there is something else that I have done stupid, have the same ones on two other tractors and they work just fine, but the rpms are substantialy higher. Thanks again, and have a gooder, R.E.L.
Post A Followup
: Re: Re: Re: 12 V Conversion - Helpful Hint
