Re: Generator output on Farmall H - 6 volt
Posted by Bob M on October 03, 2001 at 19:44:43 from (66.66.72.246):
In Reply to: Generator output on Farmall H - 6 volt posted by Jeff on October 03, 2001 at 19:15:45:
Jeff - Sounds like your new regulator may not have been adjusted correctly at the factory. Check by temporarily grounding the generator F terminal while running at full governor. You should see somewhere between 10 and 15 amps on the ammeter, and 7.0 volts (or a bit more) across the battery. If you do, the regulator is the problem. If not, problem's with the generator.
Post A Followup
: Re: Re: Generator output on Farmall H - 6 volt
