Re: Needing F30 advise.
Posted by TMAC on October 12, 2001 at 18:35:17 from (207.144.246.133):
In Reply to: Needing F30 advise. posted by Tyler on October 12, 2001 at 11:51:44:
I have been inside most every part of my '38 F30 so I can offer one suggestion. If your engine is free you can check the pistons and rings without removing the head. The I&T manual says the pistons may be removed from the bottom but it should have said ONLY from the bottom. The connecting rods are too large to fit through the sleeves. If they are in good shape continue working on those valves with penetrate if you know there are no rust problems. You will know the condition of your valves and cylinders by looking up into the engine with the oilpan and pistons removed.
Post A Followup
: Re: Re: Needing F30 advise.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
