Re: Needing F30 advise.
Posted by Bruce on October 13, 2001 at 18:21:56 from (216.179.4.123):
In Reply to: Needing F30 advise. posted by Tyler on October 12, 2001 at 11:51:44:
I'm writing to you because I'me currently restoring an F30. If the tractor has been inside all these years and the engine turns over, that's in your favor. If you can get the valves free, then it's worth it to do just that and see if it will run. If you have to pull the head, you might as well replace the guides, valves, maybe springs, and install new valve seats (nickel, so
you can burn unleaded gas. As far as I'm concerned, it makes no sense NOT to do this once you've pulled the head. Just my 2 cents.
Post A Followup
: Re: Re: Needing F30 advise.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
