Re: Re: Re: M clutch problems
Posted by Jeff on October 14, 2001 at 09:39:20 from (134.126.188.86):
In Reply to: Re: Re: M clutch problems posted by Haas on October 14, 2001 at 05:59:35:
I will try those things out. Yesterday was the first time I have ever tried to pull anything that big with the tractor. That hand clutch has never worked as long as I have had it. It doesn't even move. If it turns out to the the main clutch, what should I do? actually, if it turns out to be the hand clutch what should i do?!? Thanks for all the help.
Jeff
Post A Followup
: Re: Re: Re: Re: M clutch problems
