Re: H teardown update/need some advice
Posted by justin on October 16, 2001 at 21:23:10 from (209.23.129.7):
In Reply to: H teardown update/need some advice posted by mike in southern WI on October 16, 2001 at 20:08:42:
I would strongly suggest removing the block, and having it cleaned. There is a process that is better than the traditional boiling method. Our local NAPA has an enclosed carousel that uses an acid to remove the sludge and all the paint. When the block comes out, it looks like a brand new casting. If you need engine parts, let me know, I carry NOS parts for IH tractors.
Post A Followup
: Re: Re: H teardown update/need some advice
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in ... [Read Article]
