Re: Re: W-9 gas head on WD-9 diesel block? will it work?
Posted by Steven on October 17, 2001 at 20:59:23 from (12.23.185.169):
In Reply to: Re: W-9 gas head on WD-9 diesel block? will it work? posted by Ross on October 17, 2001 at 19:36:56:
Yes, I would understand that there are differences in the heads. That was not my question, I already knew about the decompression valves and auxilliary combustion chambers for starting on gas in the diesel engine. I also know that a gas engine wouldn't have injectors. Thank you for your reply, but:
I would like to know if there are major differences in the block and pistons. Is the combustion chamber in the head the only thing that raises the compression for the diesel or are the pistons domed also? I can certainly deal with up to about 10.5:1 compression with decreased timing and higher octane fuel.
Steven
Post A Followup
: Re: Re: Re: W-9 gas head on WD-9 diesel block? will it work?
