'48 W-6 12 Volt / Mag Alt. Wiring?? Need help...........
Posted by R. Wright on October 21, 2001 at 18:27:21 from (209.96.191.126):
I have a 1948 W-6 with a 12 volt system. Alternator and magneto wiring needed to be replaced. While finishing OTHER projects, I lost track of where the wires "reconnected to".
Currently the engine turns over but won't start. When connecting a meter to the end of the mag I have less than 12 volts coming though the wire. When checking for a spark at end of plugs, I have nothing. Alternator wires are not connected at this time because I figured it would get in the way. I only have one wire coming off the side of the mag which is connected to my GRND on key switch...... IS THIS OKAY?? I was told by one person that a wire may need to be connected from ALT to MAG, but not sure where or how. What could be the problem?? ...AND WHAT IS THE BEST WAY TO FIX IT.
Post A Followup
: Re: '48 W-6 12 Volt / Mag Alt. Wiring?? Need help...........
