Farmall Tractors Discussion Board
Re: Super A transmission help
Posted by RED on March 07, 1999 at 17:52:07:
In Reply to: Super A transmission help posted by Daniel on March 07, 1999 at 16:30:22:
Once you split the tractor, the front transmission seal is on the outside of the transmission in a bolt-on diecast housing. Changing it will be easy as long as the housing is OK. On mine, the bearing was spinning in the housing so I drilled & tapped three holes for set screws to hold the seal in place....not very hard to do.
Good Luck!
RED
Post a Followup
: Re: Re: Super A transmission help
