Re: Magneto/battery with out alternator generator?
Posted by Bob M on October 29, 2001 at 12:21:30 from (165.170.128.65):
In Reply to: Magneto/battery with out alternator generator? posted by jmyt_47 on October 29, 2001 at 11:14:30:
The setup you describe (mag ignition, battery start and no generator) is not uncommon. An owner would take a hand-start tractor, add a starter, battery, a few feet of cable - but no generator - and convert his tractor to a "budget" electric start machine.
If the motor is in good tune (starts easily), a fresh battery will provide a couple hundred starts on an H before going flat - i.e. a whole season's worth of starting. That's probably what's going on with your friend's H.
How to check (assuming no generator or alternator is present): With the motor running, pull the ground cable off the battery. If the motor keeps running, the ignition is by magneto. If it quits it's battery/distributor.
Post A Followup
: Re: Re: Magneto/battery with out alternator generator?
