Re: Magneto/battery with out alternator generator?
Posted by Zonie on October 29, 2001 at 20:26:55 from (64.12.104.59):
In Reply to: Magneto/battery with out alternator generator? posted by jmyt_47 on October 29, 2001 at 11:14:30:
I have a 48 H that had a generator that was non operable when I bought it, there was no belt or any wiring to the generator. It has a magneto and could be used for a few weeks with out charging the battery. The magneto does not draw power from the battery. It had a habit of running low on charge at the most inoppertune times, so I did convert it to a 12 volt alternator.
I can't imagine the battery would last very long if your using the lights much with out a charging system.
Post A Followup
: Re: Re: Magneto/battery with out alternator generator?
