Re: Re: Re: Farmall M-four bottom?
Posted by Denny Frisk on October 31, 2001 at 09:57:01 from (12.4.181.2):
In Reply to: Re: Re: Farmall M-four bottom? posted by Ralph on October 31, 2001 at 06:34:59:
Ralph - It's all about torque and the loads that torque puts on the shafts & bearings at right angles to the centerlines of the shafts. Einstein's theory of relativity says something about equal & opposite forces & reactions seems appropriate here. 2nd gear in an M is about 3-1/2 MPH, 3rd is about 4-1/2, and 4th is about 5-1/2. So if You take 50 HP full load in second as the baseline load, since Your still only making 50 HP, but faster speed in 3rd, the torque going thru the transmission in 3rd is only about 78% of what it was in 2nd. If You go to 4th, it's only about 64%. HP is nothing more than torque or force times speed. There's other factors involved, like as You shift up higher thru the gears of an M, the mating gears get closer to the pilot bearing between the constant mesh gears and the sliding gear shaft, and that pilot bearing IS a weak spot in the M's, but the reason it's located next to 4th gear is because the force on it is WAY less than if 1st gear was located there. The pilot bearings were increased in size in the Super Series. I've pulled 4-14's with a Super M-TA in 2nd. And Dad's '51 M would outpull the M-TA every day, so Yes, an M will pull 4-14's but it would be better off pulling 3-14's or 3-16's faster. To pull 4-14's would require more ballast to reduce slippage, and all kinds of other expenses. There's NO WAY any machine can withstand an operator determined to tear-up the equipment He's operating. Same goes for hitting rocks when plowing or ???. Didn't have any rocks where I grew up. In fact, I could never even find any arrowheads! even whan I was looking for them when I was cultivating.
Home
| Forums
Today's Featured Article -
Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
