Hand crank location
Posted by Rob on November 03, 2001 at 08:16:37 from (206.144.243.162):
I am restoring a 1947 cub. On the floorpan of the tractor I see two clips on top that could hold the crank when not in use or the battery cable.Is the cable on top or bottom and where does the crank go when not in use. It also has two clips on the bottom all are right next to the center driveline tube. Also what goes in the space just behind the bell housing, it's flat with like eight 5/8" bolt holes.
Post A Followup
: Re: Hand crank location
