Re: Farmall H steering tires
Posted by john d on November 04, 2001 at 06:27:11 from (205.188.200.42):
In Reply to: Farmall H steering tires posted by BRUCE HALLETT on November 04, 2001 at 06:15:28:
Get into the archives on this board, and you'll find it to be a fairly common problem, but one that's usually pretty easy to improve, if not eliminate. The wobble comes from accumulated wear in several places. If you've already ruled out wheel bearings, move on to the other suspects. Check the condition of the universal joint in the center of the steering shaft. These are not hard to change, and are often worn badly. A bad universal joint can be responsible for most of your problem. The little bearing at the front of the steering shaft where it exits the front of the gearbox on the top of the front bolster is a frequent cause of this, and often overlooked. It's cheap, and easy to change. While you're in there, check the sector gear to make sure it's tight, and not badly worn. Occasionally you get lucky and find one that is a full circle instead of just an arc, and it can be moved to fresh teeth. If you replace the sector gear, replace the worm gear that drives it. If the center part of that worm gear is worn to a knife-edge, it's shot. You can sometimes get away with replacing the worm gear, but not the sector gear. If the gearbox is dry - without oil - you've got bigger problems. You'll need new gears, bearings, and almost certainly the sleeve bushings in the front bolster.
Home
| Forums
Today's Featured Article -
Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
