Re: Re: Any tips for puting rubber on steel wheels?
Posted by Chums5 on November 06, 2001 at 06:02:48 from (209.240.222.132):
In Reply to: Re: Any tips for puting rubber on steel wheels? posted by walt f on November 05, 2001 at 16:17:14:
I helped my friend with an oil pull put rubber on wheels.....and did it let Walt but when we cut tire we use a Saw-Zall with a coarse metal cutting blade...cut thru rubber and large lugs like butter....also cut it 2 inches wider then steel wheel....when mounted ..1 inch each side of wheel and rubber naturally rolls around wheel after use for a so-so side wall to protect anything from wheel etc.....Good Luck....
Post A Followup
: Re: Re: Re: Any tips for puting rubber on steel wheels?
