Re: F-20 Cam Followers
Posted by Brad A (ore) on November 08, 2001 at 00:00:59 from (163.41.248.252):
In Reply to: F-20 Cam Followers posted by Mr. J on November 07, 2001 at 14:31:27:
Howdy Mr. J: The lifters are separate from the push rod guides and measure about 4' in length when you get them out. (the push rod guides are just holes in the block) As the Red Baron says, squirt them from underneath with liquid wrench, wd-40, etc. With a long punch, gently tap them up from the bottom and then tap them down from the top with a push rod. (Be Gentle, don't force anything, or you'll bend the push rod.) Continue the process until they will move into a position that you can remove the cam. ( The cam must be removed to get two of the lifters out.) They come out from the bottom end. You will probably want to remove them, as the receptacle for the push rod will be undoubtedly be full of grim and gunk. The only way I have found to clean them adequately is by removal. Brad A (ore)
Home
| Forums
Today's Featured Article -
Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
