Re: Re: Re: Re: How do you changing a starter ring gear
Posted by Denny Frisk on November 13, 2001 at 07:24:19 from (12.4.181.2):
In Reply to: Re: Re: Re: How do you changing a starter ring gear posted by Dave T on November 12, 2001 at 18:54:56:
If You've gpot a small angle grinder You can grind slots between the teeth to get the old one off, small tap with a chisel helps it fall in two pieces. I think My service manual says to only heat the new one to 375-400 Deg. in an elec. oven to prevent over-heating. It's probably best to pull the flywheel off and lay it flat while doing this repair.
Post A Followup
: Re: Re: Re: Re: Re: How do you changing a starter ring gear
