Re: OK Bob M.....what now?
Posted by Bob M on November 15, 2001 at 12:14:04 from (165.170.128.65):
In Reply to: OK Bob M.....what now? posted by Paul Shuler on November 15, 2001 at 10:52:42:
Paul - That's a puzzler!
The continuity test results with the switch unwired says the switch is OK. (Continuity test with the switch wired up is meaningless since the meter also then reads continuity on the alternator #1 line....)
Now assuming the belt is tight and the pulley is not slipping, the only other possiblility I can think of is resistance in the idiot lamp bulb or wiring has become too high to "turn on" the alternator. Verify by temporarily connecting both the #1 and #2 terminals to the BAT terminal at the alternator with the engine running at 1/2 speed or higher. If it now charges chances are you need to replace the a warning lamp with one that draws more current. A #168 or #194 automobile side marker bulb is a good choice....
Drop some airline tix in the mail and I'll make you a "house call" - you're MO weather is sounding pretty good to me!! Bob M...
Post A Followup
: Re: Re: OK Bob M.....what now?
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
