Re: Governer help
Posted by Red Dave on November 21, 2001 at 12:43:19 from (208.165.46.34):
In Reply to: Governer help posted by Larry on November 21, 2001 at 07:50:40:
I'm not familiar with F14's, but on most governors the weights (or flyballs) spin at a speed directly proportional to the speed of the governed motor. In other words, as the motor speeds up, the weights spin farther out from the shaft, pushing on the rockshaft to slow the motor. The weights should pivot freely on their pins when the motor is stopped. Can you tell if they spin when the motor turns? Most governors turn at less than motor speed usually a 2 to 1 or 4 to 1 ratio.
Hope that helps somewhat, as I said, I'm not familiar with the specifics of F14's.
Post A Followup
: Re: Re: Governer help
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
