Re: FARMALL SM GEAR SHIFT LEVERS
Posted by Farmer Bob on November 21, 2001 at 17:01:50 from (66.152.73.48):
In Reply to: FARMALL SM GEAR SHIFT LEVERS posted by Tenn Transplant on November 21, 2001 at 14:01:47:
If you aren't concerned about originality, remove the lever and use a heat wrench on it to make the bend work for you. Make sure you check it in R-2-4 so that you don't crunch your fingers against the light bar post. I made mine resemble those on the 400 which angle off to the left somewhat. Works great.//FB
Post A Followup
: Re: Re: FARMALL SM GEAR SHIFT LEVERS
