Re: 1086 overheat
Posted by the tractor vet on November 22, 2001 at 14:58:37 from (216.196.13.46):
In Reply to: 1086 overheat posted by Dan on November 22, 2001 at 14:24:39:
The lite that you are talking about is a low water level lite and some times they will trip if they are just a littel low or going bad . It might not be a bad idea to replace the thermostat to keep the engine at propper temp ( around 165 to 180) this will help prolong engine life buy keeping cylindar temp up to help burn the fuel and not washing the walls with raw fuel.
Post A Followup
: Re: Re: 1086 overheat
