Re: Governer help
Posted by Jim on November 23, 2001 at 04:59:42 from (62.7.142.209):
In Reply to: Governer help posted by Larry on November 21, 2001 at 07:50:40:
I have never worked on an F-14 tractor, but have had simular experiences with governors on other IH tractors. Check to see if the weights/flyballs are able to move freely. If they don't, a fairly cheap and easy fix is to get a can of WD-40 and spray the shaft and weights. Let it soak and spray it some more and it shouldn't take too many times before the governor starts to working properly. This is something that is almost common on Farmall H's and M's that are not used on a very regular basis. I have had to do this a few times and it worked for me. It would also be a good idea to change the engine oil and filter soon after completing this.
Post A Followup
: Re: Re: Governer help
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
