Farmall Tractors Discussion Board
Re: H upper main bearing removal and piston ring installation.
Posted by Phil Auten on March 11, 1999 at 07:53:44:
In Reply to: H upper main bearing removal and piston ring installation. posted by The Red, John Fritz on March 11, 1999 at 06:40:48:
John,
On the rings, be very careful installing them.
It's easy to break the ones made of cast iron or
steel. The oil scrapers for the bottom are not
usually fragile. Other than that, be sure they're
installed right side up so they'll scrape the oil
down, not up. There should be instructions with
directions on how to figure out top and bottom of
each type of ring and how to assemble the bottom
rings.
Phil
Post a Followup
: Re: Re: H upper main bearing removal and piston ring installation.
Today's Featured Article - History of the Cockshutt Tractor - by Danny Bowes (Dsl). The son of a very successful Toronto and Brantford, Ontario merchant, and himself quite an entreprenuer, James G. Cockshutt opened a business called the Brantford Plow Works in 1877. In 1882, the business was incorporated to become the Cockshutt Plow Company. Along with quality built equipment, expedious demand and expansion made Cockshutt Plow Works the leader in the tillage tools sector of the farm equipment industry by the 1920's. ... [Read Article]
