Re: Head work
Posted by The Red on November 27, 2001 at 06:41:07 from (206.246.187.2):
In Reply to: Head work posted by Ludwig on November 27, 2001 at 06:24:15:
Ludwig on the H project I did in 1999, I let NAPA overhaul the head. Dip, flux, shaving, valve guide replacement, seat grinding and some replacements, r&r on the manifold studs, valve and spring replacement, etc. ran around $125 in labor. I would take it in and let them have at it. The only thing I took off was the rocker arm assembly. Make sure they grind the valves and lap them to the seats. The seat is a removable piece that the valves close on.
Post A Followup
: Re: Re: Head work
