Farmall Tractors Discussion Board
Re: H upper main bearing removal and piston ring installation.
Posted by Greg on March 11, 1999 at 16:11:32:
In Reply to: H upper main bearing removal and piston ring installation. posted by The Red, John Fritz on March 11, 1999 at 06:40:48:
Red, Take a cotterpin, 1\8 in dia. put it in a vice form the top to look like a T, insert it in the main oil hole in the crank , rotate the crank , it will push the upper shell out, to install, oil the shell, start in the cavity push the shell around till it starts to bind, insert the pin, rotate crank till tab is close to its seat, push it in with screwdriver. Good luck
Post a Followup
: Re: Re: H upper main bearing removal and piston ring installation.
