Re: Farmall A What have I done!!!
Posted by gene b on November 30, 2001 at 04:45:17 from (63.186.18.183):
In Reply to: Farmall A What have I done!!! posted by Paul on November 29, 2001 at 20:14:36:
better go back to square one with registration timing marks lined up then make sure you are on compression with no1 cycl had this happen to me a long time ago dont remember which way it was but the engine would start and run like you said the manifold got red got in proper time and it has ran since the baler motors were the same as far as using tractor parts unless a CONTINETAL was used sheet metal varies some is the same as a tractor
Post A Followup
: Re: Re: Farmall A What have I done!!!
