Re: farmall h magneto and generator!help!
Posted by Theman on December 03, 2001 at 12:17:41 from (12.19.86.5):
In Reply to: farmall h magneto and generator!help! posted by IH puller on December 03, 2001 at 11:05:36:
To verify that you don't have a timing problem pull the center (coil) wire from the round cap with 5 posts on it and see if it will produce spark. If it does, you have only a timing issue. If it doesn't, go back to the points and make sure your points are working properly and that the condenser wire isn't grounded somewhere.
Post A Followup
: Re: Re: farmall h magneto and generator!help!
