Re: Re: Re: Re: Re: Pinion (Bull) shaft removal
Posted by Dagger on December 04, 2001 at 04:31:06 from (206.9.216.92):
In Reply to: Re: Re: Re: Re: Pinion (Bull) shaft removal posted by Bleedinred on December 03, 2001 at 20:01:48:
Thanks again for the comments folks. I'd be more than happy to remove the deck except that I'm from Minnesota, and I purchased this rig at an auction,(no test drive allowed) for snow removal. I am somewhat under the gun to get it done. Does the spider gear remain on the pinion shaft when removed, or does it remain in the differential assy. I'm still hoping that the brake shudder was caused by the shaft brgs. Any thoughts??
Post A Followup
: Re: Re: Re: Re: Re: Re: Pinion (Bull) shaft removal
