Re: H clutch
Posted by The Red on December 05, 2001 at 02:46:51 from (12.84.238.170):
In Reply to: H clutch posted by speed bump on December 04, 2001 at 20:11:31:
More than likely your clutch plate is stuck against the flywheel. I have one H that does this about once a year. I pull it out in the open and warm up the engine and then shut it off. I stick it in 1st. or reverse and start it in gear at idle. I run it around in the barn yard with the pedal depressed. It usually releases within a couple of minutes.
Post A Followup
: Re: Re: H clutch
