Re: Farmall H Belly Pump Leaking
Posted by The Red on December 05, 2001 at 14:25:42 from (12.84.244.59):
In Reply to: Farmall H Belly Pump Leaking posted by Will@ont.ca on December 05, 2001 at 14:21:20:
Will that is a very common problem. You will need to replace the countershaft seal and the reservoir gasket. Get help when you drop it. The assembly weighs close to 100 pounds.
Post A Followup
: Re: Re: Farmall H Belly Pump Leaking
