Re: 400 12 v conversion
Posted by bobs shop on December 05, 2001 at 16:40:38 from (209.152.80.227):
In Reply to: 400 12 v conversion posted by Karl F on December 05, 2001 at 02:04:11:
the 10si is the only way to go. i have been doing this for several years. starters are not (smart). they do not know the diff between pos and neg ground. if you want i can send you my wiring diagram and what you will need. the mount will vary with the tractor. there is no standard mount that i have found.
Post A Followup
: Re: Re: 400 12 v conversion
