Re: Farmall F-30
Posted by Bob Kerr on December 08, 2001 at 18:40:27 from (152.163.207.183):
In Reply to: Farmall F-30 posted by trac776 on December 08, 2001 at 18:05:39:
COOL! I will have one someday also! I don't know of any big problems with a distillate verses a gasoline, but I do know that distillate manifolds for an F-20 that isn't cracked is very hard to find! I am not sure if the F-30 kerosene manifold is the same design but the f-20 manifold seems to hold condesation and rain water in the bottom if it doesn't get run much. Everyone I have ever seen was welded up and looked horrible! The gas manifold is different and I don't think it has that problem. By the way, I ran my F-12 on kerosene and then on gasoline for a horsepower comparison test last summer, and the dyno said there was no difference in HP between fuels. I had to lean the carb out to run on kero so the fuel usage is less on kero but that is about the only running diference.
Post A Followup
: Re: Re: Farmall F-30
