Re: Replacement notched type throttle (M, H, etc.)?
Posted by Clem on December 10, 2001 at 11:45:01 from (63.62.86.120):
In Reply to: Replacement notched type throttle (M, H, etc.)? posted by zim on December 09, 2001 at 19:45:44:
Mine had that problem, too. I took it apart and the single tooth on the lever was worn. I took a torch and heated the tooth red hot and pushed it out with the square side of a screw driver. I ground the tooth to shape with a Dremel tool, heated it again to red hot and stuck it into some oil. It's been working ok for a couple of years.
Post A Followup
: Re: Re: Replacement notched type throttle (M, H, etc.)?
