300 worth keeping?
Posted by steveh on December 10, 2001 at 17:13:35 from (64.12.104.21):
I currently have a 300 utility that I use about 50 hours a year for mostly brushhogging and mowing. The oil pressure stays about 20 - 25 lbs per the gauge after it warms up and it leaks about a quart of oil every 90 minutes when mowing. I don't seem to have any cooling problems and it starts good. The drive train isn't giving me any problems currently. The tires are terrible and I've got some steering and brake problems. I am not a mechanic and don't want to be and I don't know of any local International mechanics (central Missouri/Lake of the Ozarks). Is this tractor worth hanging on to or would I be better off to find a newer or different model?
Post A Followup
: Re: 300 worth keeping?
Today's Featured Article - Talk of the Town: How to Remove a Broken Bolt - by Staff. Another neat discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "I have an aluminum steering gear housing with a bolt broken off in it. The bolt is about a 3/8" x 1 1/2" bolt. I've already drilled the center of the bolt out with about 7/64" drill bit the entire length of the bolt. Only one end of the bolt is visible. I tried to use an easy out but it wasn't budging and I didn't want t ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
