Re: Re: 300 U hyd.
Posted by big fred - Lance, is this the plug you mean? on December 11, 2001 at 21:15:38 from (208.51.245.74):
In Reply to: Re: 300 U hyd. posted by LanceM on December 11, 2001 at 18:28:59:
third party image
Lance, I have a plug on mine next to the pump manifold, is this what you used to drain your system? Doesn't seem like it would get more than about half the hydraulic fluid out that way. See the link for the drain that I think Tom refers to. In my case it is the return line for the power steering. I'm hoping I can drain my reservoir there. I'm in the process of getting my P/S unit off to replace the output shaft bushings.
Post A Followup
: Re: Re: Re: 300 U hyd.
